When using a keyboard script to unload a deck, the waveform remains. See photo. Happens on all decks. Win10, b3994. Any idea why?
geposted Sun 18 Feb 18 @ 9:25 am
What is the script. I'll see if I can replicate the issue
geposted Sun 18 Feb 18 @ 9:47 am
deck x unload, with x being the deck number.
TIA.
TIA.
geposted Sun 18 Feb 18 @ 10:00 am
The script works ok for me
Tested with:
Windows 7 b3994 default skin
2-deck skin and 4-deck skin
Using custom button and keyboard button
Tested with:
geposted Sun 18 Feb 18 @ 10:17 am
Default skin here as well. Only tried a keyboard script. I can try a button.
geposted Sun 18 Feb 18 @ 10:38 am
Same issue with a custom button.
geposted Sun 18 Feb 18 @ 10:40 am
Are you running on a Mac?
Because my successful test was on windows
geposted Sun 18 Feb 18 @ 10:56 am
The script on Mac works prefect. This is on a Windows 10 machine.
geposted Sun 18 Feb 18 @ 11:47 am
Then I don't know why it acts strange on your specific setup. Sorry
geposted Sun 18 Feb 18 @ 2:12 pm
Try to set experimentalSkinEngine in options to No
geposted Sun 18 Feb 18 @ 2:20 pm
Will do.
geposted Sun 18 Feb 18 @ 5:34 pm
That was the ticket! Thanks as always.
geposted Sun 18 Feb 18 @ 8:36 pm
