hi i am using virtual dj 8 and ddj sr2 controller
a track will be playing then it will freeze although the track will still play but i loose all control over the buttons on my controller such as cue play etc so i have to restart i need an answer to this asap as it has happened while im on a gig!
geposted Mon 19 Feb 18 @ 2:42 am
A quick way to keep the show running without restarting VDJ (hopefully it will help) is to go to VDJ Settings-->Controllers tab , right-click on the Pioneer DDJ-SR2 from the top-left list and choose "Reconnect"
Could be USB powering issue, bad USB cable and a million other causes.
geposted Mon 19 Feb 18 @ 2:47 am
