I tried this, but realized browsed_file_color is only a setter.
browsed_file_color 'red' ? browsed_file_color 'reset' : browsed_file_color 'red'
Then I tried different approaches of something like this:
get_browsed_color 'red' ? browsed_file_color 'reset' : browsed_file_color 'red'
get_browsed_color & param_equal 'red' ? browsed_file_color 'reset' : browsed_file_color 'red'
get_browsed_color param_equal 'red' ? browsed_file_color 'reset' : browsed_file_color 'red'
param_equal get_browsed_color 'red' ? browsed_file_color 'reset' : browsed_file_color 'red'
None of this worked, soooo... help please :)
geposted Mon 26 Feb 18 @ 8:41 am
param_equal "`get_browsed_color`" "red" ? this : that
There is a similar example in the param_equal action description (how to use actions with param_ actions )
geposted Mon 26 Feb 18 @ 9:19 am
Thanks for you response.
I saw that example, but unless I'm doing something else wrong, this won't work for me.
That is the action I believe should work. Setting the color does work, resetting does not:
param_equal "`get_browsed_color`" "red" ? browsed_file_color "reset" : browsed_file_color "red"
I also tried it with ' instead of ` but that didn't work either.
geposted Mon 26 Feb 18 @ 10:03 am
It works fine here:
<item text="Clear" action="browsed_file_color 'reset'" check="param_equal '`browsed_file_color`' 'transparent'"/>
notice that the action is
and the query is
So, most likely you want to map your button to something like this:
param_equal '`browsed_file_color`' 'red' ? browsed_file_color 'reset' : browsed_file_color 'red'
PS: As you can see I'm NOT using get_browsed_color for the query
and the query is
geposted Mon 26 Feb 18 @ 12:04 pm
Okay, got it... Thank you.
It indeed has to be
and not
param_equal '`get_browsed_color`' 'red' ? browsed_file_color 'reset' : browsed_file_color 'red'
But that opens up another question for me: What is the return value of "get_browsed_color"? There is no description in the program and as I understand it, it returns a color.
It indeed has to be
and not
geposted Mon 26 Feb 18 @ 12:14 pm
It returns the color, as color, not text.
Therefore you need to cast it into text before you're able to query it.
When you use it on a custom button as query the casting is done automatically. But when you use it inside a more complex script, you have to cast it to the correct format before you use it
geposted Mon 26 Feb 18 @ 12:37 pm
