Is there any way I can add to the history delay script of
setting 'historydelay' 31 ? off & setting 'historydelay' 999 : on blink & setting 'historydelay' 31
to include turning off and on the 'loadsecurity', so when 'historydelay' is 999, 'loadsecurity' is off, then when 'historydelay' is 31, 'loadsecurity' is on?
Thank you
Thank you
geposted Tue 27 Feb 18 @ 4:04 pm
setting 'historydelay' 31 ? off & setting 'historydelay' 999 & setting 'loadsecurity' 1 : on blink & setting 'historydelay' 31 & setting 'loadsecurity' 2
geposted Tue 27 Feb 18 @ 4:20 pm
Doesn't seem to be working. History changes but security doesn't.
geposted Tue 27 Feb 18 @ 4:29 pm
maybe it's the FRUIT skin again is the problem.
Works perfectly in my PC.
geposted Tue 27 Feb 18 @ 4:42 pm
OK, I stopped and restarted the program a couple times, changed back and forth from default to Fruit skin. It seems to be working now. Thank you!
geposted Tue 27 Feb 18 @ 6:08 pm
