Topic: Default FX
djcraigPRO InfinityMember since 2006
Is there any way of removing the default FX which come with VDJ?
It's all good and well adding new ones which you can get rid of at a later date if you don't like it or no longer use.
The vast majority of FX which come with VDJ I do not use and just clutter up VDJ and the one I like to use.
Thanks!
geposted Wed 28 Feb 18 @ 11:13 am
No, they are built in to the program.
geposted Wed 28 Feb 18 @ 11:27 am
You can right click them in the effect selection list and select ignore.
This will group all the ones you don't need so they don't clutter the list of the ones you use.
geposted Wed 28 Feb 18 @ 11:52 am
Thanks, Adion!
geposted Wed 28 Feb 18 @ 9:24 pm
