Topic: Samples and Effects
For the longest, I've been able to download samples, skins and efx. DOWNLOAD, SAVE, RUN-it would auto install the download. Now, for some reason, it says choose what program you want to open with. Do I go in and change the file extension (which I haven't looked at yet) or is something else wrong?
geposted Sat 03 Mar 18 @ 6:14 am
If you are using IE it now generally block running downloaded content in that way. The easiest fix is to use another browser
geposted Sat 03 Mar 18 @ 7:26 am
lincol2PRO InfinityMember since 2011
I now use google chrome
geposted Sat 03 Mar 18 @ 7:05 pm
