slight issue guys hopefully can be sorted in a future release... on virtual dj 7 if you had your pitch range set to say +/- 12 then you could not auto sync outside these parameters.. in 8 it will sync to whatever pitch range... sometimes by accident i end up starting a track at plus 44 etc!!please help!?!
geposted Sun 04 Mar 18 @ 4:33 pm
Turn it off in the settings then.
autoPitchRange
The VDJ manual is here https://www.virtualdj.com/manuals/virtualdj8/index.html
autoPitchRange
geposted Sun 04 Mar 18 @ 4:38 pm
Try changing the autoPitchRange setting to no
geposted Sun 04 Mar 18 @ 4:40 pm
