Topic: Auto Headphones not working
Hi I am have been having an issue for the last few gigs and I cant seem to solve it.
I'm using build b3994.
Under options my autoHeadphones is set to onload. I have tried all different settings.
I have tried with my Pioneer sx2 controller and with no controller connected.
The autoHeadphones does not work? any suggestions?
geposted Fri 09 Mar 18 @ 6:08 am
The AutoHeadphones will start working when the PFL buttons match with the selected track buttons . So try e.g. To have deck 1 selected and PFL 1 enabled (and all other PFL buttons off) and see if it works from that point
geposted Fri 09 Mar 18 @ 12:06 pm
Thanks for responding.
Makes no difference. I have even set everything back to default and still not working. I have tried it with 4 decks and with 2 decks. Is there a way I can send you a video?
geposted Fri 09 Mar 18 @ 6:17 pm
Not working even without any controller connecred ?
Sure, you can post the link of the video here or pm me
geposted Sat 10 Mar 18 @ 1:16 am
