Topic: Virtual DJ 8 doesn't show all tracks
Hi there.
I recently bought Numark Party Mix, it has a Virtual DJ LE serial I introduced and worked good.
The issue is, after a couple of months, the "PRO" part has expired. I have lost the navigation bar, which is annoying but I can still understand it's a feature they want me to pay for.
The worst part, and really annoying, is that LOTS of tracks are no longer showing into the VDJ library, as it had been deleted from the Windows directory. This will only happen if the controller is plugged in, otherwise they show up. And are random tracks, if I add new ones they appear.
It's been two weeks since I contacted the developer and no one even replied.
I run Windows 10, VDJ 8 (just reinstalled) and licence up to date.
Any clues on why is this happening?
Thanks so much!
geposted Mon 12 Mar 18 @ 4:15 pm
The browser of a LE version has some limitations, as you already figured out.
I don't know why tracks would disappear with a connected controller. But since they reappear without the controller connected it has to be a LE limitation.
Here is a licence comparison chart. But it is not very detailed.
https://virtualdj.com/products/virtualdj/comparison.html
geposted Tue 13 Mar 18 @ 8:52 am
