Topic: Virtual DJ compatibility with Pioneer DDJ-SB3
Hello. I would like to know if Virtual DJ is compatible with the new Pioneer DDJ-SB3 controller that has just come out this month. If so, how would I map it or does Virtual DJ recognise the sound card when plugged in.
geposted Fri 16 Mar 18 @ 3:03 am
Not yet supported, but will be soon.
geposted Fri 16 Mar 18 @ 3:49 am
meswindPRO InfinityMember since 2013
So when will this happen?
geposted Mon 26 Mar 18 @ 5:16 pm
Go to the wiki and check the Supported Controllers page...
https://www.virtualdj.com/wiki/VirtualDJ8%20Controllers.html
FYI the SB3 is listed there, so it is now supported. Just make sure you have the latest VDJ build.
FYI you can also check which controllers are supported by looking at the list in config within VDJ.
geposted Mon 26 Mar 18 @ 5:22 pm
Please read this.
Locked as duplicate by AMAHM
geposted Mon 26 Mar 18 @ 5:25 pm
