I am only getting sound through the right speaker when I am in channel A on the mixer and playing a proper vinyl record on the left deck, when I switch to Channel B I get sound through both speakers.
When it is on channel A and the left deck, sound comes through the right speaker only, but then when I use the amp left/righ balance to switch to the left speaker the sound comes through but only really quiet.
It all works fine in DVS mode but not properly in normal (real vinyl mode)
Please help, thanks
Please help, thanks
geposted Sun 18 Mar 18 @ 6:15 pm
Are you using any mixing hardware (dj mixer, Midi controller) ? If yes, which ones
Are you using any USB (external) sound card ? If yes, what connections have you done ?
Provide a screenshot of your current VirtualDJ Audio setup
geposted Mon 19 Mar 18 @ 12:35 pm
I'm experiencing the same problem. Currently have a Denon DS1 with Nox 404 mixer.
The settings are set atm to;
Output
deck1 Denon DS1 ASIO out 1&2
deck 2 Denon DS1 ASIO out 3&4
deck 3 Denon DS1 ASIO chain 5&6
Input
Timecode 1 Denon DS1 ASIO in 1&2
Timecode 2 Denon DS1 ASIO in 3&4
Output
Input
geposted Wed 21 Mar 18 @ 10:49 pm
Hi there.
I am using a pioneer djm250mk2 mixer, and 2 second hand numark decks, I suspect a dodgy rca cable maybe as in only getting sound through one speaker and DVS not working fully
geposted Thu 22 Mar 18 @ 1:11 pm
