After i moved a folder in vdj browser, an annoying renaming message kept flashing on top of the browser window. Anyway to stop this?
geposted Tue 20 Mar 18 @ 9:22 am
That's not a bug.
You must have at least one reference to those files residing elsewhere - so when you moved the folder, the links to those files would have been broken. VDJ is simply correcting the situation.
geposted Tue 20 Mar 18 @ 9:43 am
groovindj wrote :
That's not a bug.
Any solutions to this problem?
geposted Tue 20 Mar 18 @ 10:09 am
What is the problem you have exactly?
You moved a folder, so virtualdj tries to make sure that your playlists and virtual folders path are updated as well.
geposted Tue 20 Mar 18 @ 10:25 am
that "renaming" message kept flashing on the browser and it won't go away. Moreover I discovered yesterday another problem HID mode on CDJ-2000 nexus that the on-screen marker on needle search display kept jumping nominal rates back and forth constantly, also the display on platter screen also jumping and moving very fast. Display are not smooth and haywired on both decks. However there are no audio drop nor crash happen. I did not want to take the risks, I decided to roll back to b3994. My laptop is Lenovo Y500, i7, latest win10, 8 Gb ram, Nvidia GT750M.
geposted Thu 22 Mar 18 @ 9:04 am
