So I'm using v- DJ to broadcast my online radio show. Here is the issue. I can hear the music broadcasting clear as day, but when I use an external mic I can't hear myself talk through the broadcast. I can turn on my internal mic, but that gives a horrible sound. All of my connections are correct on my mixer (Pyle PMXU63BT), AND I am using a macbook pro if that helps. If anyone can help me that would be great. Thank you
geposted Mon 26 Mar 18 @ 3:43 am
What are you using to get your mic input from the mixer to the laptop?
geposted Mon 26 Mar 18 @ 8:16 am
The only hookup I have is using the USB port to go from the mixer to the laptop. Should I be using something else
geposted Mon 26 Mar 18 @ 11:18 am
Ok, I don't know the mixer so i don't know what it uses it's USB for
Can the mixer then be seen and used in the VDJ audio setup page?
What do you see there?
geposted Mon 26 Mar 18 @ 2:45 pm
Having just looked at the mixer & the manual on the web, I don't think it's capable of sending audio to the computer via USB.
The USB channel is for playback, from a flash drive or from the computer (they supply a USB A to A cable - very unusual).
The manual only lists USB as an input, not an output.
geposted Mon 26 Mar 18 @ 5:03 pm
