Hi,
Iv been using a touch screen with vdj and woundered if this can be done or anyone would like to have a try at developing it.
Basically a 4 decks skin.
Either....
1. A 2 touch screen setup. 2 decks on each screen with the ability on 1 side (preferably the right), or both sides to be able to switch between decks/browser view.
Or....
2. A 3 touch screen setup consisting of 2 decks on each screen and the browser on a 3rd.
Any help with this would be very much appreciated.
Thankyou in advance :)
Either....
Or....
geposted Thu 29 Mar 18 @ 8:52 am
geposted Thu 29 Mar 18 @ 10:24 am
That looks pretty cool, but not what i had in mind. Thats for sepporate i pads to remotely control vdj.
Tho a good idea, just not what i meant.
The touch screens i have are 22 inch touch screen monitors on my pc.
geposted Fri 30 Mar 18 @ 3:19 pm
It's the same thing. Skins are written for the remote in the same way as for the main software.
What you want can be done (that link was an example) and has been possible with VDJ for ten years or more.
geposted Fri 30 Mar 18 @ 4:04 pm
So does that mean i can apply the remote skins to the main software ?
I apologise now, as im not very technical when it comes to VDJ and im not familliar at all with its limits and boundaries.
I had a look at how the skins are made and tbh i didnt get it. A bit more time invested and i might stand a chance, i just literally thort that if someone has already got/made a great skin that does what im looking for then that saves alot of time and playing around ;)
For example.... the multitouch skin by dj dad. I love it. Its perfect. Id just love a 4 deck version where two decks are on each screen. That skin switches views from decks to browser perfectly for me.
I had a feeling, and totally agree with the statement that it can be done. What id really like to find out is... has it ?
Btw thank you for replying. Any help/feedback from you guys is very much appreciated :)
geposted Wed 04 Apr 18 @ 12:18 pm
I may come up with something for you (a modification of the Multi-Touch).
Quick questions
1. Which scratch-waveforms do you want see on each side, at the top ?
2. Do both of your touchsceens have the same screen resolution E.g. both are 1920x1080 ?
Quick questions
geposted Wed 04 Apr 18 @ 12:52 pm
Following
geposted Tue 17 Apr 18 @ 7:07 pm
wickedmix wrote :
https://www.virtualdj.com/plugins/index.html?addonid=80397
Is that 8 decks?
geposted Tue 17 Apr 18 @ 7:10 pm
i think its 6 have a look here http://www.virtualdj.com/forums/210189/VirtualDJ_Skins/Remote_Screen_Skins__or_how_to_have_up_to_6_big_screens_for_you_controlers_.html
check out the videos on that link
geposted Wed 18 Apr 18 @ 1:34 am
