I work 6/7 nights a week with my set-up. Last night I noticed that the left hand channel I was playing music from sounded empty, no bass at all and quite tinny even when I turned the bass up full on the controller, the right side sounded normal. It was quite a large venue so I put it down to the venue acoustics or a one off. However tonight in my regular Sunday venue the same thing happened. I've not changed any settings/configurations since Friday. Is this a common problem, has anyone experienced this before. Easy fix?
I use an HP Envy Laptop with a Denon MC6000 Mk2.
geposted Mon 02 Apr 18 @ 12:28 am
Check your filter setting for the deck.
geposted Mon 02 Apr 18 @ 12:35 am
Thanks kradcliffe, could you elaborate just a little?
geposted Mon 02 Apr 18 @ 12:42 am
The filter dial below the bass dial...
geposted Mon 02 Apr 18 @ 1:12 am
Ha, thanks. Yes it was just to the right, made a huge difference when I set it back to the middle, cheers.
geposted Mon 02 Apr 18 @ 1:31 pm
