Sorry forgot to say what is “hw”? Thanks
geposted Tue 03 Apr 18 @ 6:57 am
geposted Tue 03 Apr 18 @ 11:57 am
I don't do Mac but thought it did not use ASIO drivers?
geposted Tue 03 Apr 18 @ 9:19 pm
Yep my mistake, no asio or wasapi for macs (i is idoit :-I)
if the sound is as described, i am convinced it is a sample. This kind of intermittent fault needs experimenting with to be recreated at will.
geposted Tue 03 Apr 18 @ 9:34 pm
I have only got the samples that come with VDJ. I've never used them and only just found them and none in there sound anything like it
geposted Tue 03 Apr 18 @ 9:41 pm
I listened to the sound that you posted to YouTube. Is that the actual sound, or something that you created to mimic what it sounds like to you? Also, it seems as it is a two part sample, one short and one a little longer. Is that what you hear, with the same interval?
geposted Wed 04 Apr 18 @ 7:22 pm
No that's purely a sound that is similar as someone posted that it seems like the same problem they have, they described it as Stripped Disc so i just googled it and found that. When it happens the sound is constant
geposted Wed 04 Apr 18 @ 7:29 pm
I don't know whether this may be part of the problem or not but i'm getting conflicting opinions as to whether i should be using Core Audio or Bit accurate settings.Can anyone advise?
Im using a Numark usb controller and have a choice in Audio set up to use either of the choices. Ive been getting this noise interference on some tracks with the setting at Core Audio. I have up to date drivers for the Numark device installed and using Mac OS Sierra 10.12.6
Under the Core Audio setting i get the following :- 44 100 Hz 4 chan out 0 chan in, 512 samples
Under the Bit accurate setting i get :- 44 100 Hz 4 chan out 0 chan in, 256 samples
Might switching to Bit accurate help and should i be using that anyway?
Many thanks again for help to date
One of the Mac guys will be here to help you with that question.
So, have you run this in automix without the controller, at home to see if it still happens? Did you try re-installing the software? If not, don't do both at the same time, because then we won't know which one worked. If you re-install, make sure you say "NO" when asked about settings.
geposted Wed 04 Apr 18 @ 7:40 pm
Im running at home now and all ok so far. Trying not to change too much at once. I'm hoping maybe changing to Bit Accurate may be it plus giving VDJ exclusive audio access. I haven't reloaded software yet
geposted Wed 04 Apr 18 @ 7:52 pm
You gave "exclusiveaudioaccess" a yes awhile ago, correct?
geposted Wed 04 Apr 18 @ 7:59 pm
yes i did
geposted Wed 04 Apr 18 @ 8:41 pm
Can one of you Mac guys please answer this question from this user, thank you.
geposted Sat 07 Apr 18 @ 6:32 am
No one?
geposted Sun 08 Apr 18 @ 3:13 am
Since he has the controller, it would be easiest for him to try if Bit Accurate fixes the problem for him.
geposted Sun 08 Apr 18 @ 3:19 am
In general, which should he be using? Say he didn't have this issue, would it make a difference which one he used? Are Mac users favoring one over the other?
geposted Sun 08 Apr 18 @ 3:25 am
Bit Accurate seems to be lower latency for his controller. I don't know if it is generally better.
geposted Sun 08 Apr 18 @ 3:31 am
Hopes this gives him some insight, thank you.
geposted Sun 08 Apr 18 @ 3:40 am
Thanks guys, i used Bit accurate last night out playing live and no issues, all ok. Time will tell though as its been ok before but that was using Core Audio.
Thanks for advice to date though
geposted Sun 08 Apr 18 @ 4:49 pm
