VDJ 8.2 build 4252
W10 64x with current updates
Hauppauge USB-Live2 Driver version 6.0.119.31085
I usually use the TellyMedia and TellyVisuals plugins. But, I figured I'd give the internal plugins a shot.
When trying to select active my capture card for the camera plugin the VDJ interface froze. I was still able to use VDJ via my controller.
I kept getting the windows busy circle where my mouse cursor was. I let VDJ run like that for a little while to see if the watchdog would kick in and crash. But, it did not. I had to use the task manager to kill VDJ.
geposted Wed 18 Apr 18 @ 10:13 pm
Can you try if it also happens with the current release build 4204?
geposted Thu 19 Apr 18 @ 4:59 am
I should be able to try by Yuesday
geposted Sat 21 Apr 18 @ 4:56 am
It has the same problem with that build as well.
geposted Mon 30 Apr 18 @ 7:14 pm
