Is there a way to sync the offline cache from one laptop to another within the vdj program. It is tedious to download the same songs twice, once for each laptop. How do I do this?
geposted Sat 21 Apr 18 @ 9:48 pm
this tells you where they are stored so you can copy from one to the other https://www.virtualdj.com/wiki/Cache%20Folder%20Location.html
geposted Sat 21 Apr 18 @ 10:08 pm
Copy cache from one computer, paste to the cache on the other computer.
geposted Sat 21 Apr 18 @ 10:10 pm
so I would basically copy the cache folder, share it to say a external drive, then move it back? Wonder if I could set them up to share across bluetooth or wifi somehow? Or maybe start a network group or something?
geposted Sat 21 Apr 18 @ 10:14 pm
I set up a home network, then use a program called free file sync. It does the trick, and very easy to use.
geposted Sun 22 Apr 18 @ 11:38 am
Thanks guys. I bought a thumb drive and just update the cache on the second laptop the day before the event now. Seems to work seemlessly.
geposted Sun 25 Aug 19 @ 5:00 pm
Hi,
Is it possible that my old laptop cashe will be deploy on my other laptop . Even the Music I am using with external drive. Because my new laptop SSD drive is capacity is too low.
geposted Sat 09 Nov 19 @ 5:07 am
