Possible to get a total time on the songs in the karaoke panel? Already there for the playlist panel. TIA.
geposted Wed 25 Apr 18 @ 5:14 am
I am pretty sure if you select them all, right click and select "Tag Editor" it will show you a total time in the pop-up window.
geposted Wed 25 Apr 18 @ 1:39 pm
I'll check it out.
A permanent display would be more useful IMHO.
geposted Wed 25 Apr 18 @ 1:40 pm
DMayock13 wrote :
I'll check it out.
Agreed. It would be.
geposted Wed 25 Apr 18 @ 1:44 pm
Not sure if you are using already, but if you show the Will Play At column, that does give you an idea of time. Might work in the interim.
geposted Tue 08 May 18 @ 1:26 pm
