Will the Virtual DJ Remote work for the Samsung Chromebook?
geposted Tue 08 May 18 @ 2:31 pm
No, it's Android & iOS only.
You could use Chrome remote desktop however.
geposted Tue 08 May 18 @ 3:19 pm
I think Chrome OS recently got the ability to run Android apps?
geposted Wed 09 May 18 @ 7:03 am
geposted Wed 09 May 18 @ 4:58 pm
Now that Chromebooks can run play store apps I purchased the remote app. It works but does not recognize the larger, wider screen of my chromebook. It just runs like it would on a small phone screen, in a vertical orientation and only showing the tabbed single deck layout.
My actual phone is running Android Pi (version 9) and doesn't connect to the VirtualDJ host software at all. It just times out. It looks like the last update to the remote app was back in 2015. Kinda disappointing......
geposted Fri 15 Mar 19 @ 1:22 am
