What do you think if.....
Currently artist is displayed on the top line, with title below. How about if clicking on artist changed it to show artist & title on one line?
Then with the top line showing both artist & title, the lower line could be clicked on to show year/genre/comment in one line.
This is easier than trying to shuffle things around and creating new new text areas.
geposted Mon 22 Apr 19 @ 1:45 pm
Sure, that would work for me, I'd be happy with any config within these boxes, if I have to click within it or a particular line, then so be it, at least I'd have the said info at my finger tips, instead of having to (as I do at the moment with this skin) have to re-search for the track within the browser to find the info.
So yeah, that'd be great, thank you
geposted Mon 22 Apr 19 @ 2:23 pm
Not sure if it works in this skin, but usually the cover art has a tooltip that contains album and year.
The cover art can also be clicked to show a drop-down where one of the options is to open the tag editor so you could look up all the info.
geposted Mon 22 Apr 19 @ 2:43 pm
Ok, I'll take a look at that, thank you
geposted Mon 22 Apr 19 @ 3:16 pm
OK here's what I've done. First image is default. Second is clicked.
Normal title and artist
Combi artist - title on top line, info below
geposted Mon 22 Apr 19 @ 3:29 pm
Thank you, that looks exactly what I am after :-)
geposted Mon 22 Apr 19 @ 3:45 pm
Now updated to Virtual dj 8.3,fix some minor bugs and change some things
New platter design,more options on master window
In this version the views of 4 and 6 decks were eliminated even though deck 1 and 2 are interchangeable by decks 3 and 4 by pressing the right button of the mouse on the number of the deck or with the deck change button that the controllers
Greetings and thanks
geposted Thu 23 May 19 @ 4:09 pm
VDJ DARK updated, cool when is it gonna be ready to download? love it...Thanks for the update.!!!
geposted Sat 25 May 19 @ 5:44 pm
in this moment is pending for validate for the developer team
geposted Sun 26 May 19 @ 7:15 am
Hi, why did you eliminate 4 and 6 decks?
geposted Sat 06 Jul 19 @ 10:02 pm
to lighten the set anyway you can work with 4 decks, these are inverted by clicking on the right button mouse of the deck number or with a controller dedicated button
geposted Sun 07 Jul 19 @ 1:40 pm
Yes I know, I just found it useful to have the option of a 4 decks view and see the 3rd and fourth decks just small under the 1st and 2nd... :)
Hope you will bring it back in the end! :D
geposted Wed 10 Jul 19 @ 4:43 pm
any chance of adding a button for the event scheduler on the skin?
geposted Sun 29 Dec 19 @ 5:51 am
You can add it yourself, with a custom button.
geposted Sun 29 Dec 19 @ 9:29 am
Beautiful . Few minor issues . The blue lights around the white dot (under pitch bend) don't switch off when Auto's are off (except Auto Sync on Play) . Also when i put the mouse pointer on it shows different actions - for example - Master Tempo , Smart Loop.Tnx
geposted Mon 28 Feb 22 @ 7:07 pm
I've been wanting a video skin like this forever. Then here you come and grant my wish. Thank you for making my video mixing so much easier. Now I can see both videos clearly, on a larger screen, so transitioning between the two is much more precise. You killed it with this. No changes necessary with this skin.
geposted Sat 07 Jun 25 @ 8:07 pm
