On Mac High Sierra with the latest.
MC is acting like my 2 is set to thru.
Deck one fades off nice with the CF, but 2 has no separation what so ever.
This happened at an event where Chris Roman from In Music was working with me.
I asked him to have a look but was just as puzzled.
He cleared the midi log and it began working.
I went to use it again this weekend and it was back to its old tricks again.
In cofig, the unit is picked up and assigned properly #1 1/2 #2 3/4 but makes no difference.
Anybody else having this problem?
geposted Fri 11 May 18 @ 10:40 am
How about setting Audio to Master & Headphones ?
How are your switches at the back set as ? http://www.virtualdj.com/manuals/hardware/denon/mc6000/setup.html
geposted Fri 11 May 18 @ 1:01 pm
Audio set to master/phones 1/2
Back is set to Mac/int but it didn't seem to matter on the sound side.
geposted Fri 11 May 18 @ 3:29 pm
Its acting like a driver issue if it was a pc
Dating myself, but I remember having to assign cards in midi sound control.
I run different gear on this machine because of 3 different set ups.
After Chris cleared the midi device memory it worked fine for 3 days.
So I dunno, but I can't put my finger on software, device or system settings at this point.
geposted Fri 11 May 18 @ 4:28 pm
Intermittent hardware fault perhaps?
geposted Fri 11 May 18 @ 4:32 pm
Never had an issue in 7 but haven't tried it.
Hard to pinpoint, but settings appear correct, but its acting exactly like line 3 is set to thru.
geposted Sat 12 May 18 @ 6:26 pm
Just a thought, ha e you checked your crossfader settings on the front of the unit
geposted Sat 12 May 18 @ 9:30 pm
That is the first thing I looked at.
What changed the symptom was clearing the other midi devices.
I use CDJ's, Dicers, Reloop and the 6k
Another weird thing is VDJ will not pick up my SL2 sound card.
With the millions of these that were sold, I can't be the only one having this problem.
geposted Sun 13 May 18 @ 2:10 pm
Would easy check it for you but don't have a Mac.
geposted Sun 13 May 18 @ 2:20 pm
Any word on this from the Gods?
geposted Fri 18 May 18 @ 10:51 am
When back switch is set to INT MIX instead of PC MIX, the correct VDJ Audio setup should be External mixer (deck 1->Chans 1,2 and deck 2 ->Channels 3,4)
If the separation of channels is still not proper...
Goto Audio Midi Setup (from Applications->Utilities). Do you see the MC6000 as 4out ? If so , click on "Configure Speakers" (i think that's how it should called) and set it to 4 speakers - Quadrophonic mode.
Also try by not setting the MC6000 as default Mac sound card.
geposted Fri 18 May 18 @ 4:49 pm
Man I tried every setting I could find and still puzzled why I can't use the sl2 card for sound.
The confusing thing is the terms I guess.
PC always meant internal mixer on the software side.
External meant where a usb sound card was in use with a standard mixer.
Yet we're setting the 6k to int and sound setting to ext where normally a controller is 1/2 main/ 3/4 monitor and my head is spinnin lol.
I remember having to select quad in midi sound to get 4 channel to work way back, think that is the way to bring in the sl2?
The sl2 does appear in hardware, but not in the vdj config as a usable sound device, whereas in windows its discovered and used with no problem.
geposted Sun 20 May 18 @ 4:33 pm
If you want to use the SL2 and not the MC6000 sound card, then you should set the back switcher to PC MIX, so that the audio mixing/routing is not done from the MC6000 and use the device as a pure MIDI device and not as stand-alone mixer.
You audio setup should use the SL2 i guess (at least for Master)
So something like..
Master .. SL2 ..Chans 1,2
Headphones .. MC6000... Chans 3,4
http://dj.rane.com/support/downloads
I see Sierra compatible drivers, but not High Sierra update
So something like..
geposted Sun 20 May 18 @ 10:11 pm
