Hi.
Is there any chance the auto mix section could have the mix lengths added as buttons on the top - along side the button to turn auto mix on and off?
Would make my life much easier as I'm always having to go in to the menu to select mix length.. even if it just had 0, 4, 8, and 16 seconds (as I use these the most) that would be awesome.
Thanks
Thanks
geposted Mon 14 May 18 @ 9:47 am
You can make a pad page for it, so you can control it with one mouse click, the keyboard, or on your pads if your controller has them
Something like this:
geposted Mon 14 May 18 @ 10:20 am
