I wish we can broadcast at 256kpbs and also wish you can put the mic option like on vdj6. Thanks
geposted Fri 18 May 18 @ 1:07 pm
The mic option depends on your hardware.
If your controller doesn't send mic input to the laptop (some send it straight to master out) the software will never receive it, and then can't broadcast it, unless you loop it back to the laptop in some other way
The same rules applies for adding mic to recordings in VDJ
geposted Fri 18 May 18 @ 2:25 pm
