locodog wrote :
param_equal `get_var a` `get_var a & param_cast 'text' 1` ? SIZE OF 1 :
param_equal `get_var a` `get_var a & param_cast 'text' 2` ? SIZE OF 2 :
param_equal `get_var a` `get_var a & param_cast 'text' 3` ? SIZE OF 3 :
param_equal `get_var a` `get_var a & param_cast 'text' 4` ? SIZE OF 4 :
Thank you !
geposted Thu 17 Nov 22 @ 1:18 pm
Someone asked for a midnight countdown video effect, but I was thinking that it would maybe be simpler to add it to a video skin
But that will need some scripting
I assume the value could then be taken from comparing 23:59:59 to get_clock cast to maybe an integer, then param_multiply -1 and param_add to get the difference, maybe adding the missing second, and then showing the value?
But I can only figure out how to do the first few steps...
geposted Sun 04 Dec 22 @ 6:10 am
I've done it, I just need to remember how I did it.
*edit, I found it and I remember the problem now. It needs to be started at a known time.
[it monitors saved clock state v current clock and if different, -1 from the countdown, some maths, and resave new clock state]
Problem root is, get_clock, it returns a string so it will only cast the hour value as an int [the : breaks it]. And we've got nothing for casting substrings.
get_clock 'hour'
get_clock 'min'
get_clock 'sec'
would be one fix, for this specific problem, but that isn't real script currently.
param_cast 'text' SIZE INDEX
would be another more round about fix, it would have other uses too, but again doesn't exist.
I suppose it could be brute forced to get the time in a usable form but that would be pretty ugly.
[I'll see how it looks]
Or windows I could make a plugin
geposted Sun 04 Dec 22 @ 6:24 am
I'll add a countdown script to make this easier
geposted Sun 04 Dec 22 @ 7:17 am
thanks that would be good, I've just done the script way anyway.
not easy I suppose I'll post it here in the off chance I need it in the future,
plus to remind myself how to do stuff
get hour,min,sec as vars
timer to midnight
send to text plugin
I played with it a little bit just see second by second changes, this uses text presets for size font & position, so it will only work if you have them saved ["time","number","message" in my case]
this bit replaces the end bit
timer to midnight
send to text plugin
deck master repeat_start runClock ?
var $showCount 1 ?
on & set $showCount 0 & deck master effect_string 'text' 2 "GENERIC MESSAGE" : off & set $showCount 1 & deck master effect_active text on :
set $showCount 1 & deck master effect_active text on & deck master effect_string 'text' 2 "COUNTDOWN" &
set $minString `get_clock 24 & param_cast 'text' 5` &
set $secString `get_clock 24` &
set $hours `get_clock 24 & param_cast 'integer'` &
set $min 0 &
set $sec 0 &
set $time `get_var $hours & param_cast '00' & param_cast 'text'` &
set_var $char ":" &
set $time `param_add 'get_var $char' 'get_var $time' & param_cast 'text'` &
set $time1 $time &
( param_smaller 10 `get_var $min` ? set $min `param_add 'get_var $min' 'get_text "0"'` : ) &
set $time1 `param_add 'get_var $min & param_cast 00' 'get_var $time'" & param_cast 'text'` &
repeat_start_instant minRun 25ms 60 &
var_equal "$minString" "$time1" !?
set $min `param_add 'get_var $min & param_cast "integer"' 1` &
( param_smaller 10 `get_var $min & param_cast 'integer'` ? set $min `param_add 'get_var $min & param_cast "text"' 'get_text "0"'` : ) &
set $time1 `param_add 'get_var $min & param_cast "text"' 'get_var $time' & param_cast 'text'` :
repeat_stop minRun &
set $time `param_add 'get_var $char' 'get_var $time1'` &
set $time1 $time &
( param_smaller 10 `get_var $sec` ? set $sec `param_add 'get_var $sec' 'get_text "0"'` : ) &
set $time1 `param_add 'get_var $sec & param_cast 00' 'get_var $time'"` &
repeat_start_instant secRun 25ms 60 &
var_equal "$secString" "$time1" !?
set $sec `param_add 'get_var $sec & param_cast "integer"' 1` &
( param_smaller 10 `get_var $sec & param_cast 'integer'` ? set $sec `param_add 'get_var $sec & param_cast "text"' 'get_text "0"'` : ) &
set $time1 `param_add 'get_var $sec & param_cast "text"' 'get_var $time' & param_cast 'text'` :
repeat_stop secRun &
repeat_start_instant correction 25ms 6 &
var_equal "$time1" `get_clock 24` !?
set $hours `get_var $hours & param_cast 'integer'` &
set $min `get_var $min & param_cast 'integer'` &
set $sec `get_var $sec & param_cast 'integer'` &
( cycle $sec 60 & var $sec 0 !? : cycle $min 60 & var $min 0 !? : cycle $hours 24 ) &
set $time3 `get_var $hours & param_cast '00' & param_cast 'text'` &
set $time3 `param_add 'get_var $char' 'get_var $time3' & param_cast 'text'` &
set $time3 `param_add 'get_var $min & param_cast "00"' 'get_var $time3' & param_cast 'text'` &
set $time3 `param_add 'get_var $sec & param_cast "00"' 'get_var $time3' & param_cast 'text'` &
set $time1 $time3 :
repeat_stop correction &
set $countdown `param_add "param_multiply 'get_var $hours' 3600" "param_multiply 'get_var $min' 60"` &
set $countdown `param_add "get_var $sec" "get_var $countdown"` &
set $day 86400 &
set $countdown `param_multiply "get_var $countdown" -1 & param_add 86400` &
set $time `get_clock 24` &
repeat_start_instant runClock 25ms &
var_equal $time `get_clock 24` !?
set $countdown -1 &
set $cdHour `param_multiply 'get_var $countdown' 'get_constant 3600 & param_1_x' & param_cast 'int_trunc'` &
set $cdMin 0 &
set $cdSec `param_mod 60 'get_var $countdown'` &
set $cdMin `param_add 'param_multiply "get_var $cdSec" -1' 'param_multiply "get_var $cdHour" -3600' ` &
set $cdMin `param_multiply "param_add 'get_var $countdown' 'get_var $cdMin'" "get_constant 60 & param_1_x"`&
set $time3 `param_add "get_var $char" "get_var $cdHour & param_cast '00'" & param_cast 'text'` &
set $time3 `param_add "get_var $cdMin & param_cast '00'" "get_var $time3"` &
set $time3 `param_add "get_var $char" "get_var $time3"` &
set $time3 `param_add "get_var $cdSec & param_cast '00'" "get_var $time3"` &
( var $showCount 1 ?
get_var $time3 & param_cast & deck master effect_string 'text' 2 : var $showCount 2 ? deck master effect_string 'text' 2 "Happy New Year!" : ) &
param_equal `get_var $time3` "00:00:00" ? set $showCount 2 & wait 1000ms & repeat_stop runClock & wait 29000ms & deck master effect_active text off & set $showCount 0 & deck master effect_string 'text' 2 "GENERIC MESSAGE" : :
( var $showCount 1 ? effect_string text 3 "time" &
get_var $time3 & param_cast & deck master effect_string 'text' 2 : ) &
param_equal `get_var $time3` "00:00:10" ? set $showCount 0 & effect_string text 3 "number" & effect_string text 2 "10" :
param_equal `get_var $time3` "00:00:09" ? set $showCount 0 & effect_string text 2 "9" :
param_equal `get_var $time3` "00:00:08" ? set $showCount 0 & effect_string text 2 "8" :
param_equal `get_var $time3` "00:00:07" ? set $showCount 0 & effect_string text 2 "7" :
param_equal `get_var $time3` "00:00:06" ? set $showCount 0 & effect_string text 2 "6" :
param_equal `get_var $time3` "00:00:05" ? set $showCount 0 & effect_string text 2 "5" :
param_equal `get_var $time3` "00:00:04" ? set $showCount 0 & effect_string text 2 "4" :
param_equal `get_var $time3` "00:00:03" ? set $showCount 0 & effect_string text 2 "3" :
param_equal `get_var $time3` "00:00:02" ? set $showCount 0 & effect_string text 2 "2" :
param_equal `get_var $time3` "00:00:01" ? set $showCount 0 & effect_string text 2 "1" :
param_equal `get_var $time3` "00:00:00" ? set $showCount 2 & effect_string text 3 "message" & deck master effect_string 'text' 2 "Happy New Year!" &
geposted Sun 04 Dec 22 @ 10:49 am
don't mind me I was just making an edit.
geposted Mon 05 Dec 22 @ 10:01 am
timer to midnight
send to text plugin
timer to midnight
send to text plugin
Crazy stuff!
Here is my video on it:
And... we may also need a script that turns it off again, so that the text fx returns to normal :)
geposted Mon 05 Dec 22 @ 10:29 am
