Hi Guys
I have a Gemini GV4
the software witch came with the Gemini has been install but when I want to put in the serial number , it says Serial Number is invalid
Can somebody help me please
Without the serial number I can only use the Trial version witch is limited and all the Functions on the controller are not working
I hope I can get a solution
I have a Gemini GV4
geposted Sat 19 May 18 @ 6:13 pm
Go to my account ^up there, then licences your serial is there.
geposted Sat 19 May 18 @ 6:16 pm
Some Limited Edition versions are available only for version 7, so if you are trying to enter its keycode in version 8, it wont work.
Visit http://www.virtualdj.com/le/ , enter your LE serial/keycode and see if it offers ver 7, ver 8 or both and install VirtualDJ from there.
If you still have troubles, please contact Support
geposted Sun 20 May 18 @ 9:40 pm
Hi Guys,
Thanks for your help
I got it fix.
I got it fix.
geposted Mon 21 May 18 @ 2:01 am
how to get virtualdj9
geposted Fri 04 Jan 19 @ 12:56 am
Wait if and until they release it. Also, it’s impolite to highjack someone else’s thread.
geposted Fri 04 Jan 19 @ 2:05 am
I need virtual Dj pro serial
geposted Thu 11 Jul 19 @ 8:00 am
There are no pro serials anymore
It's based on credentials instead - as in: the logon you used when you bought the pro license
You buy the license right here: https://virtualdj.com/buy/index.html
geposted Thu 11 Jul 19 @ 8:05 am
