Topic: Black screen
I just changed the skin to mixlab and everything froze and now when I start VDJ8, I only get a black screen.
Alienware, I7 quad core 2.6, 16 GB, Win 10, VDJ8.2
Thanks
geposted Sun 20 May 18 @ 7:48 pm
Can you answer these questions for me? Go into Documents, VDJ, Skins, delete that skin. Does VDJ open now?
geposted Sun 20 May 18 @ 7:57 pm
It made no difference.
Thanks!
geposted Sun 20 May 18 @ 10:40 pm
I don't know what exactly happened, but my PC sound is completely gone as well. Currently running scans to determine what I need to do to fix the sound.
geposted Mon 21 May 18 @ 1:13 am
close from task manager, then reload VDJ then try pressing SHIFT+ESC to open Options if it will let you then try switching skins from there if it opens
geposted Mon 21 May 18 @ 1:34 am
Fixed the sound by updating the drivers.
Thank you both. The last suggestion worked.
geposted Mon 21 May 18 @ 3:52 am
Out of interest, when you say "mixlab" which version exactly are you referring to?
There are several Mix Lab skins by DJ Format, and various mods by other people too.
geposted Mon 21 May 18 @ 4:57 pm
