Topic: USB Audio Soundcard not available
DJoBoJaHome userMember since 2018
I bought a week ago a new USB adapter (USB-jack in+jack out "https://images-na.ssl-images-amazon.com/images/I/31QwBuNYYzL._SX466_.jpg") because the controller I have doesn't have jack in/out so I need two jack out from my PC. It worked until yesterday but now Virtual DJ says that the USB adapter isn't available. I tried withouth Virtual DJ and the adapter works, so it's a problem of Virtual DJ, soultions?
Edit: when the external controller isn't connected to PC and I'm using Virtual DJ with the PC keyboard USB adapter works, when I connect the controller it works for 10 seconds and responds to command(Main, Cross-Fader, ecc.) and then stops.
geposted Mon 21 May 18 @ 8:58 am
Which controller is that ?
If it doesnt come with VirtualDJ LE, then you will need to purchase a License to unlock and fully use the controller.
geposted Mon 21 May 18 @ 2:34 pm
