Good day fellow DJ's,
I have recently downloaded Virtual DJ 8.2 Pro and I find it all slightly crazy with loads of extra things on screen I will never use (such as effects, album art, scratch controls and master volumes).... I'm much more familiar / set in my ways with the older versions but cant seam to find anywere to download them after upgrading my PC....
I would like to simply change the skin if thats possible seeing as there is many so I can have a more simpler lay-out mainly with 3xcues and a loop board to mix my personal tracked albums together.... Any and all advice is deeply appreciated as I have spent hours with 8.2 and my dinosaur ways are struggling to get comfortable with the controls.
Many thanks in advance,
Ryan aka Dj Ganty
Ryan aka Dj Ganty
geposted Sun 27 May 18 @ 8:57 pm
https://virtualdj.com/plugins/index.html?addonid=80622
https://virtualdj.com/plugins/index.html?addonid=80328
Try these for size, although to get exactly what you want, I'd use the skin builder, might be a bit early for that though
geposted Sun 27 May 18 @ 9:46 pm
