Topic: DISABLE TRAKTOR z1 COMPLETELY
I DJ from Traktor using a z1 controller but I also use Virtual DJ for Karaoke using the internal sound card...... even when I select ignore Z1 / disable....... Virtual DJ is still being controlled via my z1 .... How I can make it forget for good ??
geposted Tue 29 May 18 @ 1:42 pm
At some point there was a bug with Ignore, so make sure you are on the latest Build 4291
geposted Tue 29 May 18 @ 5:24 pm
Yes I'm on 4291 so it must be still bugged .... I would go back to using virtual DJ 7 but that keeps coming up with an error on High Sierra :-(
geposted Wed 30 May 18 @ 5:49 am
Maybe I'm missing something, but if you don't need the Z1 when using VDJ for karaoke - why don't you unplug it?
geposted Wed 30 May 18 @ 4:37 pm
