Hi there is there anyway to change the waveform transparency where you load a track to how it was in virtual dj 7 pro as even with the pro 7 skin its still transparent
reason being in pro 7 you could see exactly when the beat dropped as it was solid colour now its all see through which makes it more tricky any help thanks lee
geposted Tue 29 May 18 @ 2:05 pm
Which waveform? The overall one at the top or the individual deck one?
Which skin are you using?
geposted Tue 29 May 18 @ 2:30 pm
not the one at the top one underneath where you load your songs im using virtual dj pro skin but its still transparent
geposted Tue 29 May 18 @ 3:30 pm
coloredWaveforms = Monochrome
skinPlayheadShadow = No
geposted Tue 29 May 18 @ 3:53 pm
is that what i have to change and if so how thanks
geposted Tue 29 May 18 @ 5:43 pm
Search options for these settings
geposted Tue 29 May 18 @ 5:53 pm
nice one much appreciated
geposted Tue 29 May 18 @ 6:01 pm
