Discussion about Minimalist UX 2
geposted Fri 08 Jun 18 @ 6:12 pm
I like the circle wave form. Can you teach me how to edit to remove the titler display. Thanks.
geposted Sat 09 Jun 18 @ 9:19 am
Simply click "edit skin" at top right corner in the skin settings view.
Then VirtualDJ auto extracts the files, and make an open folder called (Edit) on end.
This folder has an xml file that you can open in a text editor, and should be fairly easy to see where the titles are, and remove those.
But will make a few variants of the skin, and add to it, one without titler etc. Coming up :)
geposted Sat 09 Jun 18 @ 9:34 am
How about having a big BPM display in the centre?
geposted Sat 09 Jun 18 @ 10:00 am
Thank you for creating these video skins. One of my favorite so far is "Circle Titler Black - No feat remix [light overlay]". How would I edit the .xml file to position it on the top left and adjust the size to make it slightly smaller.
geposted Mon 11 Jun 18 @ 3:15 pm
Disregard, I just found out how much notepad ++ makes projects like that so much more easier. Just took some adjustments.
geposted Mon 11 Jun 18 @ 3:55 pm
Yeah, the minimalist skins are meant as a bit of inspiration, as much as actual use.
Feel free to play around with the xml, adjust and position.
The xml code is very light and short in these skins, easy to learn and practice on
geposted Mon 11 Jun 18 @ 3:57 pm
Thank you very much.
geposted Tue 12 Jun 18 @ 1:33 pm
How can I make my own backround,but steel have the circle!!!
(Thank you so much for the Video Output)
geposted Sat 10 Oct 20 @ 4:06 pm
Just use Slideshow video effect (for image(s) and/or video clip(s)) or sampler...
Or use Shader video fx for visualizations
geposted Mon 22 Mar 21 @ 12:58 pm
Master level does not work when selecting a song
Not level master
Not level master
geposted Thu 14 Mar 24 @ 4:32 pm
works here, now you've posted on 2 skins that you're not getting master output.
It probably your audio setup, does it have a master out?
geposted Thu 14 Mar 24 @ 4:41 pm
I get the same issue here. The audio reactive stuff only responds when playing deck 1. When playing 2, 3 or 4 the title displayed changes but no reaction from the graphics.
I've noticed it before on similar videoskins. Sometimes the audio spectrum thingy works, sometimes it doesn't.
geposted Thu 14 Mar 24 @ 5:18 pm
I think I found the problem. On variant 4 (the circle) there was no deck="master" as per the other variants.
geposted Thu 14 Mar 24 @ 10:08 pm
