If you need extended support, contact our Support Team.
Forum Guidelines (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
I can't add telly media into the master effects which then allows me to turn on the camera, lottery and now the shader without overlaying over the logo and text i have running horizontally across the screen. Any chance that can be added back in please.
Sometimes the options in the settings are grey'd out and i can't make any changes but that happens while songs are playing
That's all 'ive spotted so far at my live gig.
Great update.
thanks
geposted Fri 08 Jun 18 @ 10:02 pm
1. Like Lockie2000 above, I cannot close the zone after resizing the screen capture area. I can turn it off, but the window itself does not disappear.
2. I'm missing the "Title" video effect so I cannot put on screen the song title / artist of music videos that i'm playing.
3. 3rd party plugins seem to crash the VDJ application when trying to modify settings. Specifically i'm trying to edit the settings on my BBE Sonic Maximizer plugin, version 4.0.1 (latest version). When I try to edit the settings, the application on Windows 10 Pro becomes non-responsive and i'm forced to close the program through task manager and relaunch. The current song will continue to play, but will not automix, and the UI becomes unresponsive.
I'll continue to test, but I noticed these within about 15 minutes of trying the alpha (beta?). I won't be installing this on any machine yet that will be doing any actual performances. There's a lot of promise, but seems to be missing some important pieces for me.
geposted Sat 09 Jun 18 @ 2:50 am
lockie2000 wrote :
Can't close Screen Grab after resizing the box
This is a Windows bug. We implemented a workaround that will be released tomorrow.
If you mean the videoskin, go in Config on the Interface page, and select "{none}" in the videoskin list at the bottom
This is a known problem, we're still looking into it.
The new VideoSkin option is supposed to replace the "Title" video effect. But we'll post back the "Title" plugin on the addons section very soon.
We have very little control over 3rd party crashes, obviously.
Do you mean that in VirtualDJ 8.2, it works without crash, but the exact same action in VirtualDJ 2018 crashes?
geposted Sat 09 Jun 18 @ 2:59 pm
geposted Sat 09 Jun 18 @ 3:33 pm
geposted Sat 09 Jun 18 @ 5:05 pm
geposted Sat 09 Jun 18 @ 7:23 pm
In VDJ8.XX i could load TellyVisuals into the Master effects drop down menu and then later when i launch another thing like, slideshow, lottery, a video sample or the camera it would stay behind the TellyVisuals - rather than taking over the screen in front of it. It looked seamless.
Thanks for all the hard work
I can make a video of what i mean if needed.
Thanks
Colm
geposted Sat 09 Jun 18 @ 9:29 pm
geposted Sun 10 Jun 18 @ 3:20 am
VDJ 2018 is not stable enough to use as yet.
Video systems have always been tricky to configure.
geposted Sun 10 Jun 18 @ 11:36 am
Now with the AOV slot on the skin it is getting much closer to something normal. The activation of AOVs has alway been automated and you have no direct control over their activation except choosing 'none' . Consider that slot to be a special sort of deck slot. It still has some odd behavior but it is much better believe me. It would take months probably to explain how it worked before to most of you.
Not sure why they are calling the skin slot video source and why in options they call it visualization. Looks like the same thing to me. Also program should have none as a selection in skin slot like in options. Strange behavior when it just disappears but not nearly as strange as before. Also looks like if you one video on one deck and not the other, the vis does not come up for the other deck. Just when you remove both videos. Anyway needs work but much better.
geposted Sun 10 Jun 18 @ 2:25 pm
2.When Video open , the Settings Text not there . cant read .
3.How can I open the GUI from an Video_Source Visual effect , how Milkdrop , also with an button on Skin , the mapping "show_gui 'video_source'" dont work ??!!
4.When I close the Program , than Virtual DJ not real closed , is is in the Taskmanager from Windows and must closed manualy .
Greatings Dani
geposted Mon 11 Jun 18 @ 3:24 am
I'm a little frightened of asking what is an AOV?
geposted Mon 11 Jun 18 @ 10:16 am
bigron1 wrote :
Since the video tab on the skin does not work very well with shaders maybe just putting them on the master tab might be good?
AOV = Audio only Visual :-)
geposted Mon 11 Jun 18 @ 10:18 am
geposted Mon 11 Jun 18 @ 11:16 am
On the video tab if I go to the shaders settings (gear wheel) using the small slider I can with difficulty turn them off.
geposted Mon 11 Jun 18 @ 2:21 pm
Video Skin: this is not showing on my output monitor (by this I mean the mimic display on my VDJ skin), I have played around with a few settings, and I was so excited with new things to play with , I can't remember if it was on the mimic display to start with lol
Video skin: ooh your going to have to turn it off for Karaoke, its going to get in the way of the on screen words: my suggestion would be a config option Suspend Video skin on karaoke play
geposted Mon 11 Jun 18 @ 4:25 pm
Agreed.
geposted Mon 11 Jun 18 @ 4:35 pm
My first impression about video skins is that it will work ok for audio only but not when doing video. You don't have any idea what will be playing for video. It can change often etc.
geposted Mon 11 Jun 18 @ 10:15 pm
geposted Mon 11 Jun 18 @ 11:28 pm
Yes that's by design. The Video Skin is actually a skin with all kind of elements, that can replace the pure Video Output. It doesnt make much sense to have these skin elements on the Video preview on the main skin, which in most of the cases will be too small to see the details
Yes, for karaoke makes sense to have either a different Video skin or just pure Video Output. A workaround is to have a button assigned as..
setting 'videoskin' '' ? setting 'videoskin' 'for Broadcast/:broadcast' : setting 'videoskin' ''
and whenever you start your Karaoke show, to use this button to select/toggle between 2 of them.
geposted Tue 12 Jun 18 @ 12:13 am
