Discussion about Minimalist UX 3
geposted Fri 08 Jun 18 @ 10:16 pm
Hi .. please How To Use this Video Skins ?
Help me
Help me
geposted Sat 09 Jun 18 @ 3:06 am
In VDJ 8.3 (aka Virtual DJ 2018).......
Open the VDJ config window and select the tab for changing skins. The video skins are listed below the main skins.
geposted Sat 09 Jun 18 @ 6:58 am
i also cannot find out how to use this, there is no tab in the settings for me to select this skin, i am using version 8.2 and do not see the video skins listed under the normal skins
geposted Wed 13 Jun 18 @ 4:55 am
Get the recent update.
geposted Wed 13 Jun 18 @ 5:08 am
is there no way to use them on 8.2?
geposted Wed 13 Jun 18 @ 5:16 am
Correct
geposted Wed 13 Jun 18 @ 5:20 am
I love this Interface, but, can there be a version without the analyser?, just showing the song title? as I want to run advertising in the background,
Thanks.
Thanks.
geposted Tue 01 Oct 19 @ 10:34 am
Hey quick question...is there a way to move the text and spectrum to another area of the screen as well as resizing it? I video stream online and have various scenes where the text and spectrum sections need to be moved and/or resized. I would like toalter the XML file for the skin and rename it so I have different versions of the same skin.
Is there an xml manual for making changes and if so where do I find it?
geposted Tue 27 Oct 20 @ 3:43 am
There's a skin SDK in the wiki.
https://www.virtualdj.com/wiki/SkinSDK8.html
geposted Tue 27 Oct 20 @ 9:03 am
You can change it easily yes, its not that many xml elements in the skin...
Size and position are easily read from the xml
https://www.virtualdj.com/wiki/Modify%20a%20Skin.html
geposted Tue 27 Oct 20 @ 9:54 am
