Discussion about Cue Scratch
This pads page offers the same Scratch patterns as the default Scratch page.
Additionally,
Cue Scratch Pads page
Cue Scratch Pads page when SHIFT is pressed
Changelog:
ver.1.01
Additionally,
- HotCue selection :
- Hold SHIFT (or right-click) and Pad 1 to 8 and select Hotcue 1 to 8. Repeat to un-select. When a Hotcue is selected, the Scratch will start applying from the Hotcue position
- If the selected Hotcue doesn't exist, the scratch will apply from the current position, but will also assign the selected HC number to the current position
- If no Hotcue is selected, the Scratch will apply from the current position. - You can edit the Scratches (in DNA Editor) from the Pads page Menu
- Parameter 1 selects the Hotcue (0 for none), same as if you use SHIFT+Pads
- Page supports 16 Pads (with 16 scratch patterns in total and 16 Hotcues to select
Changelog:
ver.1.01
- Fixed typo on Pad 4
geposted Sun 10 Jun 18 @ 3:19 am
How to get the scratch DNA on pads
geposted Mon 16 Jul 18 @ 4:40 am
It's a native pad in the any of the '18 builds.
geposted Mon 16 Jul 18 @ 4:45 am
Additionally,
Changelog:
ver.1.01
Additionally,
Changelog:
ver.1.01
can not find in pads only in effects
geposted Mon 16 Jul 18 @ 6:37 am
What build of VDJ are you using? What skin are you using?
geposted Mon 16 Jul 18 @ 6:39 am
I am sorry i found it i was looking in the wrong place
geposted Mon 16 Jul 18 @ 7:00 am
Bump
I downloaded and installed but dont see a pads section nor is it in sampler am i using the wrong skin i tried the default VDJ 8 Skin
geposted Tue 19 Mar 19 @ 7:28 pm
Hulo i have a problem with cue scratch. I cant save scratch patterns. Pliz help me ma djz
geposted Sun 15 Dec 19 @ 10:01 am
Hi there, still cant save the scratch pads.
geposted Mon 05 Jun 23 @ 9:39 am
