Hello.
The New Original Skin shows no more the Transitions .
There is now only Video Soource and Video Effect.
And Milcdrop and others is no more under Effects selectable.
This is no good .
Why Atomix put new Funktions in and the others are away?
Greatings Dani
This is no good .
Greatings Dani
geposted Sun 10 Jun 18 @ 3:11 pm
I think another dropdown shows up when you load a video on a deck
geposted Sun 10 Jun 18 @ 3:29 pm
clic on (transitions)
geposted Sun 10 Jun 18 @ 4:11 pm
Ok ow I have this found...
Have this optimized in my other Skin also.
But I don't like it , that only can change it in the select menue :-(
This is complicated.
I find something like this out.
But for users who don't know each other so well, it's hard. These think the function is gone.
Also unpractical times just switch.
I think you should not insert a button in the panel;-)
geposted Sun 10 Jun 18 @ 9:26 pm
It switches automatically when you load a video track.
I don't think you need to select a transition if not playing video?
geposted Sun 10 Jun 18 @ 9:40 pm
