Hi.
Can the team come up with assigning audio effects to individual samples.... without opening 4 decks. It would help me Remix better. Not master effect the whole sampler but individually each sample with some pro effects... love the scratch DNA by the way.... super job … its perfect. The only thing VDJ needs to step up is its audio effects to pro levels.... adding a Freeze Delay out to some of them as well.
Thanks Guys.
Sean T
Thanks Guys.
Sean T
geposted Sun 10 Jun 18 @ 6:41 pm
Effects can be applied to Sampler already. Here is a way , using Pads .. https://www.virtualdj.com/plugins/index.html?addonid=80601
Alternatively, you can use a Skin which offers Sampler Effects as skin elements. https://www.virtualdj.com/plugins/index.html?addonid=80677
The selected Effect in the Sampler Slot will be applied to any playing sample at that time.
geposted Sun 10 Jun 18 @ 11:06 pm
Thank U … Thats great.... will try it .
geposted Mon 11 Jun 18 @ 5:12 am
