For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: Problems with finding songs
Hello guy's
I have an issue with my Virtual Dj, recently (maybe with some of the updates) I started to have problem with browser and finding a song that I have in my pc, I can go to the playlist or folder and find it manually, but that's pain in ass and taking too long, if I can not find that song by search. It's just some songs not all of them, but all are some of the songs I playing the most, so I'm quite desperate to solve this problem. Does someone has same problem ? is there anyway I can fix it ? I tried to reinstalling program, reset settings, nothing seems to work.
Thank you.
geposted Thu 14 Jun 18 @ 12:26 am
Make sure the drive with the content is set to "add to search database". Also make sure that the audio, video, and karaoke icons are selected, (whichever ones that you use) to the left of the browser.
geposted Thu 14 Jun 18 @ 4:03 am
this has happend to me if there is a ( , ) or a ( ' ) in the name it will not find the song. if i take the apostrophe out it then finds it but the apostrophe is in the song title
geposted Mon 18 Jun 18 @ 6:57 pm
