Topic: Kindly HELP
KRISH55PRO InfinityMember since 2009
Hey Everyone,
I just picked up a Audio 6 Dj Soundcard from NI, So I don't know how to do the sound card routing or settings using a external mixer,,,ie I end up using the shortcut keys & trackpad for playing. Ive tried.
Another issue is the same buy using the Z2 NI Mixer + Audio 6 Dj....how do I do the settings using my soundcard A6 & getting the LEDs to work on the Z2 as an external mixer. So do I need to use the USB plugged in from the Z2 to light up as a normal external mixer would? Kindly show me the right way.
Finally does anyone know how to remove the track info via script for the new video skin but still keeping the Dials & waveforms . I have no clue about scripting.
Thanks,
Sean T
geposted Mon 25 Jun 18 @ 10:19 am
blckjckPRO InfinityMember since 2008
Hey Sean,
I used to use the Audio 6, it's a great sound card. If your using it to just play out to a stand alone mixer, look here:
http://www.virtualdj.com/manuals/virtualdj8/settings/audiosetup/externalmixer.html
If your trying to use it fot timecode:
http://www.virtualdj.com/manuals/virtualdj8/settings/audiosetup/timecode.html
However, it appears the Z2 has it's own audio interface that is supported as well as the midi controls. You don't need the Audio 6 when using the Z2:
http://www.virtualdj.com/manuals/hardware/ni/z2/installation.html
geposted Tue 26 Jun 18 @ 2:04 pm
