I cannot login and with my internet connection is all ok. But now i found an error that keeps saying that system is unstable because of crack installed. And this sis when i open vDJ8. WTF? i have bought a licenc why do i need ti install a crack. Anyway even if in my computer is a ckrack where or how do find that sonofabitch and remove him? Please hel.
Allready uninstalled 3 times and downloaded again and installed... nothing
THX
THX
geposted Thu 28 Jun 18 @ 7:10 pm
Support staff wrote :
geposted Thu 28 Jun 18 @ 7:51 pm[ selected best answer by locoDog on Fri 19 Apr 24 @ 1:10 pm ]
Selected as best answer geposted Thu 28 Jun 18 @ 7:51 pm
I have a recently bought a lisence and now i cannot login it marks cannout connect to servers cause of som crack need help pleaseeeee
geposted Sat 06 Oct 18 @ 12:07 pm
Have you had a cracked version installed before?
Because that may have changed your network settings to avoild VDJ talking to the servers
geposted Sat 06 Oct 18 @ 12:19 pm
I think I may have had a crack file installed before. How do I reset the network settings again ?
geposted Sat 16 Feb 19 @ 10:33 pm
Nem tudok podcast csinálni
geposted Sat 16 Feb 19 @ 10:41 pm
use the tool for pc or mac that I linked to earlier.
geposted Sat 16 Feb 19 @ 10:44 pm
Hi. What’s the tool called ?
geposted Sun 17 Feb 19 @ 7:38 am
Hmm, strange, it's been removed, oh well try this
DEMMIX wrote :
go to C/Windows/system32\drivers\etc\hosts and open it with notepad and search a "127.0.0.1 live.virtualdj.com " delete it and save the file to the desktop since it won't let you save it directly to that folder and then delete the host file and replace it with the saved file
geposted Sun 17 Feb 19 @ 7:53 am
Thanks so much for your help.
How much does it cost for the home plus version as I only use my controller for at home. I have a Mixtrack Platinum
geposted Sun 17 Feb 19 @ 2:03 pm
geposted Sun 17 Feb 19 @ 2:43 pm
I have another problem. I am trying to use ITunes which I can see on the file bar. But when I select a track it won’t play any idea
geposted Sun 17 Feb 19 @ 8:35 pm
Apple Music subscription tracks?
If so they will be DRM and only play on Apple devices.
geposted Sun 17 Feb 19 @ 8:42 pm
If they are from iTunes Music subscription, they will not play. It is a DRM thing.
geposted Sun 17 Feb 19 @ 8:43 pm
This comes up all the time. Mods/Atomix can we:
- update the FAQ to include a reference to Apple Music (not that I’m sure this will reduce the number of inquires here TBH). If it has been updated I may have missed it. All I found was the old reference to old iTunes DRM.
- improve the error message inside VDJ to include a help message or link to the FAQ to help people with troubleshooting. Or I suspect it is possible to find a marker inside the file which shows it is DRM-encumbered and show an appropriate message.
Just a couple of thoughts.
geposted Sun 17 Feb 19 @ 9:47 pm
Thanks for your help
geposted Mon 18 Feb 19 @ 7:30 am
The file extension for Apple music protected files is m4p, so they should by default not even show up in the browser
geposted Mon 18 Feb 19 @ 7:52 am
What if they're in a playlist? Will the playlist show the tracks?
geposted Mon 18 Feb 19 @ 6:24 pm
Shouldn't do, as I understand only file types listed in options will show in the browser.
geposted Mon 18 Feb 19 @ 6:27 pm
I cannot connect my virtual dj 2018 to the servers and the link that had the fix tool in the previous posts no longer works, what can i do
geposted Wed 18 Sep 19 @ 1:29 pm
