Can u explain how the reverse effect does it's thing but it returns in tempo with the song instead literally reversing the entire song leaving you where u started the reverse effect?
is there a terminology to describe that sort of synchronization I'm trying to correlate it on mobile device but I need to describe the technological aspect of what it is that makes it synchronize?
I feel lowkey silly asking this lol
And is it even possible to fit that
Complex onto a mobile app??
geposted Tue 03 Jul 18 @ 4:11 am
the terminology you mean is "slip" (slips back to where it should have been) and the scripts to reverse with slip is called "dump"
you'll find keys " u & j " have a dump script on them for the optional default keyboard mapping
geposted Tue 03 Jul 18 @ 4:23 am
