Forum: Addons
Topic: Title (Video Skin)
geposted Sun 08 Jul 18 @ 12:48 pm
Congratulation on the new Video Skin Nicely done, Instead of 25 & 15 Title & Art Time out, I changed it to 25 & 25 Title & Art Time out for my Personal use the Extra 10 second warning at the end work better for me. Thanks again for a job well done keep up the great work.!!!
fdilonez wrote :
..I changed it to 25 & 25 Title & Art Time out for my Personal use
Thank you, a good alternative to the 'old titler', but -excuse my ignorance- which is the right way to change videoskin for personal use?
Great titler. Works perfectly. Is there a way to add the year to this as well?
Is there a way to animate it in and out?
Hello to all of you
Please how can i ndowload and install addons Title (visualization Video) in virtual DJ 8 ?
I did a lot of research on it and I can't find myself.
I use a macbook Pro and I have version 8.2.4514 of Virtual DJ
Your contributions will be of great importance to me.
THKS
Always use latest version of VirtualDJ. Your version is a bit old.
Download latest here : https://virtualdj.com/2020
Or turn on checkUpdates in VirtualDJ settings
After that you should have full access to all plugins easily within the software, under Extensions in settings
how did you change the times?
Dan, Thanks for this incredible video skin! Is there a way to map/trigger the titles on an off using a button on my controller instead of by crossfader position? Basically I just want to be able to toggle the title on and off manually for each deck.
Answered in your other post.
Great Skin but can i add the Year to it??
Find the zip file in the VDJ folder (C:\Users\*\Documents\VirtualDJ\VideoSkins), copy it somewhere else, extract it, edit the .xml file, rezip and overwite the one in the vdj folder.
I understand this is an old post....... How do you set this up?
I...
1. Installed it;
2. Chose it via Options>Interface>Video Skins
3. Opened the video window..... and see nothing
I tried installing other plugins like this, and they instantly work..... Well, I say some other work
Did you load and play a track? This is a title skin, so only displays the title when a track is playing.
Yes....... That said, "Title GX 1" fails too...... "Minimalist UX 1 & 4" work.
Have tried several times to download but always failed, Is there any solution
@henryrae91 licence users only.
