when i open vdj it asks me if i want to update so i click on yes it looks like it is updating then comes back with message automatic update faied do you want to try again
geposted Mon 09 Jul 18 @ 8:39 pm
Have you tried to update it manually?
I mean by downloading the new installation file on the site and over-install it on your machine?
Maybe this is a bug occurring from your last installation...?
(Make sure you don't have moved any important source files during or after the last installation.
Otherwise perform a new & clean installation and install it with the recommented paths)
https://virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20installation%20of%20the%20software.html
geposted Wed 11 Jul 18 @ 5:27 am
Mine is doing the same thing. I finally gave up and clicked on "No" for the update so I can use the program. Been working fine for years, so this installer version must have a bug in it.
Curt
Curt
geposted Fri 13 Jul 18 @ 10:25 pm
Update manually until a fix is found
http://www.virtualdj.com/download/build.html
geposted Fri 13 Jul 18 @ 10:30 pm
