Topic: Load on wrong deck
DjbooztPRO InfinityMember since 2015
Hello! I have a Proposal for a function. When u load on a playing deck deck u get a popup window. My proposal is if u Accident load on wrong deck it will not load anything and take away the popup window because it’s a annoying moment because u have 2 use the mouse to close it.. so.. when u load on playing deck.. nothing will happen only when u load on a deck witch is stopped
geposted Sat 14 Jul 18 @ 5:00 pm
You can set securityLoad to silent.
Also, you don't have to use the mouse to close the dialog.
You can also use Escape on your keyboard, or Back/Exit on your controller if it has such a button.
geposted Sat 14 Jul 18 @ 5:21 pm
