searching hasn't yielded results, both in the forum or in Options, and it might be I even missed it, but this is one of the pet peeves that is really annoying when I need to have access to all the video effects the moment I open VirtualDJ- but could we please have an option start with the "old school' way it started up showing transitions and video effects? or is there already a way of doing it that I missed when searching? as it is now I have to start it up, drag a video to a deck and then I can get to the full menu tree
geposted Sun 15 Jul 18 @ 3:37 pm
Just curious, but why would you need to select a transition without any video loaded?
(You can still select Transitions from the video source menu if you do need it btw)
geposted Sun 15 Jul 18 @ 4:42 pm
Working on AutoVXF when this change happened and it disturbed my way of doing stuff, but as you say, load a visual.
geposted Sun 15 Jul 18 @ 6:01 pm
Adion - anything that adds an extra step to get to something that was a default and gave instant access without having to load anything or click on something is an interruption in workflow.
walk in club, turn everything on, drop a few tracks in Auto, set up transition, screen crawls and graphics to run that night and then pour in caffeine. sure it's ritual, but it's a comfortable one. and I always thought the fewer steps in a workflow the better?
as to why I would need Transition menu without a video loaded - If I have a mixed list of video and audio in automix then it doesn't automatically switch to the dual preview.
and for some reason as I sit here and test this... it did not load the first video in an automix list after an audio track had played through and a video was playing..
well this is weird. it's not automatically activating video screen on load in automix.
video on load is still check "yes"
will see if I can get a screen capture
geposted Sun 15 Jul 18 @ 8:19 pm
geposted Sun 15 Jul 18 @ 8:29 pm
