when playing videos ,if i go into the setting colum it freezes and wont rest, i have to restart, plus i can't record music my mic stays on and no music records only whats on the mic
geposted Tue 17 Jul 18 @ 4:27 pm
Setting column? Do you mean settings?
Does it crash?
Are you using an up to date version of vdj.
Also your laptop specs could be useful
Does it crash?
geposted Tue 17 Jul 18 @ 4:58 pm
Where did you get the music? It may be copy protected if you didn't buy it.
geposted Tue 17 Jul 18 @ 5:04 pm
im a video jockey, i have the newest version of the software, my laptop is fine, i was using the previous version with no issues, but this version has a lot of issues, when i change my skin or take out my hdmi cable the volume goes up untill it pared with the software
geposted Fri 20 Jul 18 @ 3:04 pm
Are you using the latest licensed version or a cracked copy?
I do 3 gigs a week all video with no issues whatsoever.
geposted Fri 20 Jul 18 @ 3:24 pm
i paid for mines sir
geposted Fri 20 Jul 18 @ 6:04 pm
the video jitters and looks funny
geposted Fri 20 Jul 18 @ 6:08 pm
what are the specs of this computer?
what format are you recording in...
how are you playing back the recordings?
this is why you are being asked about your license see image.
geposted Fri 20 Jul 18 @ 7:01 pm
1. PC or Mac?
2. Can you post a picture or screen shot of your audio (sound card) configurations?
3. Which version and build number of the software are you using?
4. Please register your software to make sure that you have all the functions available to you, thank you.
geposted Fri 20 Jul 18 @ 9:12 pm
