Hi .
I'm searching for an VST Plugin , the Name is Prodyon Asteroid.
When I look on Google I found only old Links from it , 2007-2010.
And the Programmer Page from it no more exist :-(
Her one of the Links I have found.
https://www.kvraudio.com/product/asteroid_by_prodyon
But no Link where I can find this.
Who knows where can find it ?
Greatings Dani
Greatings Dani
geposted Mon 30 Jul 18 @ 8:22 pm
Have search for this asteroid.vst-effect from 2008 too,
but think it heavy to find it ,and have not found it on any vst-side:
Look up on this vst-effect think is good too:
https://www.kvraudio.com/product/truc-by-de-la-mancha/details
or direct :
https://delamanchavst.wordpress.com/2013/12/05/truc2-modulated-multi-effect-is-now-free/
You can look too for other Free and Pay VST Effects on my German Tuturial Side:
Tuturial: VDJ 8 Pro Infinity und Free VST Effekte sowie Demos zu Kauf VST Effekt Plugins:
http://de.virtualdj.com/user/vlnjacki/blogs/5202/VDJ_8_Pro_Infinity_und_Free_VST_Effekte_sowie_Demos_zu_Kauf_VST_Effekt_Plugins.html
Greatings,Dirk
When you find it,iam intrestet too in this vst effect plugin,when i find it i post this here.
or direct :
Greatings,Dirk
geposted Fri 10 Aug 18 @ 12:31 pm
Thanks Dirk.
I had already googled a lot after that, but you can't find it, so I asked here. Could be that someone knows something or has it yet.
is already a bit older, just like the links which one finds of it (KVR ect.).
Had somehow liked this VST.
Thank you many other vsts I own as well as the TRUC2.
When You have the Program FL Studio , You can also use the Effector and Grossbeat in Virtual DJ .
Need these only kopie in the VST folder from virtual DJ ;-)
Had only searched for it because have many FX with XY pad.
Greats Dani
If you ever see something, let me know ;-)
Greats Dani
geposted Fri 10 Aug 18 @ 4:32 pm
VDJ have XY pad (rarely used by skinners)
https://imgur.com/ANLfd6O
This example one is for one effect only (already possible to select a composite effect with locodog's virtualFX/DIY)
it may easily be hacked to select 2 different sliders from 2 different effect
in one word : can be skinned in VDJ with some work
geposted Mon 13 Jul 20 @ 12:29 am
Which skin is it?
I only know the XY from the Tablet Skin and the Reloop Touch Skin.
These have the function.
I simply installed the Reloop Touch Skin in my skin as a window for docking onto the second monitor.
Then I also have it when I need it
geposted Mon 13 Jul 20 @ 2:55 pm
Tried fine that plugin, pretty sure i had it at one of my older computers, but no luck so far ...
If i find it i'll upload it ;-)
(the company behind it is long gone, so i doubt its available anywhere )
geposted Mon 13 Jul 20 @ 4:59 pm
Cool .
Hope You fine it :-)
geposted Mon 13 Jul 20 @ 5:10 pm
But it will probably be 32 bit, which means you can't use it with VDJ 2021.
geposted Mon 13 Jul 20 @ 5:24 pm
Pretty sure it was both, most are
geposted Mon 13 Jul 20 @ 6:25 pm
@djdutschi
It's a stand alone "skin addon" used as an example for an uploaded plugin (review pending)
geposted Mon 13 Jul 20 @ 10:23 pm
Nicotux wrote :
@djdutschi
Oh ok, I thought you would have seen that on a finished skin.
Ok, then I'm curious about it
geposted Tue 14 Jul 20 @ 12:13 am
Plugin was refused by team
VB_8decks have it integrated since beginning
http://www.virtualdj.com/plugins/index.html?addonid=81157
geposted Thu 31 Dec 20 @ 11:19 am
