Topic: PROBLEMAS CON MI LICENCIA
HOLA SOY NUEVO EN ESTO DE COMPRAR LICENCIAS, AYER COMPRE UNA DE ESAS QUE SE RENUEVAN CADA 30 DIAS Y FIGURA COMO ACTIVA PERO CUANDO CONECTO EL CONTROLADOR Y ME PIDE QUE ME REGISTRE SALE QUE NO ES POSIBLE CONECTARSE A LOS SERVIDORES DE VDJ, EN LA FACTURA ME AVISAN QUE HAY TIEMPO HASTA EL 04/08 PARA ENTREGAR EL PRODUCTO SERA POR ESO QUE NO PUEDO INGRESAR O ESTO ES UNA ESTAFA Y PAGUE MI LICENCIA Y NO LA PUEDO USAR? ALGUIEN PODRIA DARME UNA EXPLICACION, GRACIAS.
geposted Thu 02 Aug 18 @ 2:49 pm
1) Please stop SHOUTING
2) You need to post in English, or use the correct forum for your preferred language
3) If VDJ is telling you that it cannot connect to servers, then you probably have (or had) an illegal cracked version of VDJ installed. You need to clean your computer using the tool provided in the download area.
Click here for the link.
geposted Thu 02 Aug 18 @ 6:09 pm
