Forum: Addons
Topic: Pad FX
geposted Fri 03 Aug 18 @ 2:04 am
How Can I change the effects on the pads? for example remove the echos and add like the beatgrid etc
Thank you!
I have one more question, how can I map pad 1 to BFX-Pan 100% and 1/8 beat, then Pad 2 to BFX-Pan 100% 1/4 beat ? I tried but when I click pad 1 it activated both pads.
if you use padfx as action it should only light up the one with the params you choose.. . If I remember right.
Sure you set correctly the params part?
Edit
Tested quickly here, and seemed padfx didnt take into account the buttons, only the slider (that is 100% for both actions, and hence both lights up)
But if you do something like this instead, it should work fine:
padfx 'BFX-Pan' 100% smart_pressed && effect_button 'BFX-Pan' 1
padfx 'BFX-Pan' 100% smart_pressed && effect_button 'BFX-Pan' 2
As much as I like these pads, I find once I have used them that I loose all my normal post fader fx control for the normal fx slots. Would anyone know how I can fix this please. Thanks.
