Discussion about Skin Creator
Detailed information can be found at https://www.virtualdj.com/forums/225078/VirtualDJ_Skins/Skin_Creator_-_Beta.html
geposted Mon 13 Aug 18 @ 10:13 pm
opened skin creator, then karaoke skin (just to experiment with - I loathe karaoke) and dragged to highlight multi-select elements in karaoke skin - crashes every time. not sure if it's me or the creator.
geposted Mon 20 Aug 18 @ 11:46 pm
The app closes regularly and it's painful to work with.
Is this normal?
For example, once a skin is made, I save it and open it via vdj pro 8 to see how it looks.
When I want to reopen with skin creator, I can not edit anything because skin creator closes automatically.
It is unusable.
Is this normal?
It is unusable.
geposted Thu 20 Sep 18 @ 7:49 am
Hello, excellent tool, very intuitive and powerful, how do I place classic rhithm or style waveform ?... Thank you and sorry for my English
geposted Mon 07 Jan 19 @ 11:19 am
Is this still being developed?
geposted Wed 16 Oct 19 @ 8:15 pm
Hola djdad me podrías pasar el link de ese programa.. porfavor muchísimas gracias
geposted Fri 14 Jan 22 @ 5:38 pm
Hola ayuda..
Cómo hago para crear un panel browser para mostrarlo y ocultarlo
Y un botón para que haga esa acción.
geposted Sun 23 Jan 22 @ 3:00 am
